path: root/include/configs/MPC837XERDB.h
2010-07-16powerpc: Update configs to properly set FSL_ELBCBecky Bruce
Some parts that have an Enhanced Local Bus Controller weren't setting CONFIG_FSL_ELBC. Fix this so we can use this define properly going forward (currently it's only used if PHYS_64BIT is set, which meant not all platforms needed to have it set correctly). Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-22mpc83xx: turn on icache in core initialization to improve u-boot boot timeKim Phillips
before, MPC8349ITX boots u-boot in 4.3sec: column1 is elapsed time since first message column2 is elapsed time since previous message column3 is the message 0.000 0.000: U-Boot 2010.03-00126-gfd4e49c (Apr 11 2010 - 17:25:29) MPC83XX 0.000 0.000: 0.000 0.000: Reset Status: 0.000 0.000: 0.032 0.032: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.032 0.000: Board: Freescale MPC8349E-mITX 0.032 0.000: UPMA: Configured for compact flash 0.032 0.000: I2C: ready 0.061 0.028: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 1.516 1.456: FLASH: 16 MB 2.641 1.125: PCI: Bus Dev VenId DevId Class Int 2.652 0.011: 00 10 1095 3114 0180 00 2.652 0.000: PCI: Bus Dev VenId DevId Class Int 2.652 0.000: In: serial 2.652 0.000: Out: serial 2.652 0.000: Err: serial 2.682 0.030: Board revision: 1.0 (PCF8475A) 3.080 0.398: Net: TSEC1: No support for PHY id ffffffff; assuming generic 3.080 0.000: TSEC0, TSEC1 4.300 1.219: IDE: Bus 0: .** Timeout ** after, MPC8349ITX boots u-boot in 3.0sec: 0.010 0.010: U-Boot 2010.03-00127-g4b468cc-dirty (Apr 11 2010 - 17:47:29) MPC83XX 0.010 0.000: 0.010 0.000: Reset Status: 0.010 0.000: 0.017 0.007: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.017 0.000: Board: Freescale MPC8349E-mITX 0.038 0.020: UPMA: Configured for compact flash 0.038 0.000: I2C: ready 0.038 0.000: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 0.260 0.222: FLASH: 16 MB 1.390 1.130: PCI: Bus Dev VenId DevId Class Int 1.390 0.000: 00 10 1095 3114 0180 00 1.390 0.000: PCI: Bus Dev VenId DevId Class Int 1.400 0.010: In: serial 1.400 0.000: Out: serial 1.400 0.000: Err: serial 1.400 0.000: Board revision: 1.0 (PCF8475A) 1.832 0.432: Net: TSEC1: No support for PHY id ffffffff; assuming generic 1.832 0.000: TSEC0, TSEC1 3.038 1.205: IDE: Bus 0: .** Timeout ** also tested on these boards (albeit with a less accurate boottime measurement method): seconds: before after 8349MDS ~2.6 ~2.2 8360MDS ~2.8 ~2.6 8313RDB ~2.5 ~2.3 #nand boot 837xRDB ~3.1 ~2.3 also tested on an 8323ERDB. v2: also remove the delayed icache enablement assumption in arch ppc's board.c, and add a CONFIG_MPC83xx define in the ITX config file for consistency (even though it was already being defined in 83xx' config.mk). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-22mpc83xx: enable command line autocompletionKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-02-22mpc83xx: remove hardcoded network addresses from config filesKim Phillips
and avoid e.g., two identical boards from causing random networking conflicts when hooked up to the same network. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-26mpc83xx: retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfieldsKim Phillips
some LCRR bits are not documented throughout the 83xx family RMs. New board porters copying similar board configurations might omit setting e.g., DBYP since it was not documented in their SoC's RM. Prevent them bricking their board by retaining power on reset values in bit fields that the board porter doesn't explicitly configure via CONFIG_SYS_<registername>_<bitfield> assignments in the board config file. also move LCRR assignment to cpu_init_r[am] to help ensure no transactions are being executed via the local bus while CLKDIV is being modified. also start to use i/o accessors. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: accommodate larger kernel sizes by defaultKim Phillips
linux mpc83xx_defconfig kernels are getting bigger, accommodate for their growth by adjusting default load and fdt addresses. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: mpc8377erdb - change DDR settings to those from latest bspKim Phillips
when using Linus' 83xx_defconfig, the mpc8377rdb would hang at boot at either: NET: Registered protocol family 16 or the io scheduler cfq registered message. Fixing up these DDR settings appears to fix the problem. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27mpc83xx: CONFIG_83XX_GENERIC_PCI is now synonymous with CONFIG_PCI; remove ↵Kim Phillips
the former Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-18MPC837XERDB: fix warning: "CONFIG_SYS_MONITOR_LEN" redefinedWolfgang Denk
2009-07-16mpc83xx: MPC837XERDB: Add support for FSL eSDHCAnton Vorontsov
This patch adds support for eSDHC on MPC837XERDB boards. The WP switch doesn't seem to work on RDB boards though, the WP pin is always asserted (can see the pin state when it's in GPIO mode). FSL DR USB and FSL eSDHC are mutually exclusive because of pins multiplexing, so user should specify 'esdhc' or 'dr_usb' options in the hwconfig environment variable to choose between the devices. p.s. Now we're very close to a monitor len limit (196 bytes left using gcc-4.2.0), so also increase the monitor len by one sector (64 KB). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-14mpc83xx: increase MONITOR_LEN to offset growing painsKim Phillips
Saving the environment leads to overwriting u-boot itself, bricking boards. Increase u-boot's image size so the environment base address doesn't end up overlapping u-boot text. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-1283xx: Replace CONFIG_MPC83[0-9]X with MPC83[0-9]xPeter Tyser
Use the standard lowercase "x" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc83xx: MPC837XERDB: Add PCIe supportAnton Vorontsov
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe slots. Let's support them. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-14Remove unwanted ';' at end of define.Selvamuthukumar
Currently this is not creating any problem. But it will result in compilation error when used as below. printf("CFG_SDRAM_CFG2 - %08x\n", CFG_SDRAM_CFG2); Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com> continuation of the theme based on git grep "^#define CFG_.*;$" include/ Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-24mpc83xx: don't disable autobootKim Phillips
bootdelay set to -1 'permanently' disables autobooting, even if bootcmd is specified. Change to a positive value to allow autobooting when a bootcmd is set. Reported-by: Coray Tate <Coray.Tate@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-24mpc83xx: add h/w flash protection to board configsKim Phillips
the operating system may leave flash in a h/w locked state after writing. This allows u-boot to continue to write flash by enabling h/w unlocking by default. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-25mpc83xx: bump loadaddr over fdtaddr to 0x500000Kim Phillips
this seems as a good compromise between human memory, typing, and last but not least, to accommodate for current and future kernel bloat. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com>
2008-04-11mpc83xx: Fix the SATA clock setting of 837x targetsDave Liu
Currently the SATA controller clock is configured as CSB clock, usually the CSB clock is 400/333/266MHz. However, The SATA IP block is only guaranteed to operate up to 200 MHz as stated in the HW spec. The bug is reported by Joe D'Abbraccio <ljd015@freescale.com> This patch makes the SATA clock as half of CSB clock. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc83xx: enable the SATA interface on mpc8315 rdb and mpc837x rdb boardsKim Phillips
2008-03-2583xx/fdt_support: let user specifiy FSL USB Dual-Role controller roleAnton Vorontsov
Linux understands "host" (default), "peripheral" and "otg" (broken). Though, U-Boot doesn't restrict dr_mode variable to these values (think of renames in future). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25mpc83xx: Set PCI I/O bus-address base to zero.Scott Wood
The device trees for these boards describe PCI I/O as starting from address zero from the device's perspective. Placing I/O elsewhere may cause problems with certain PCI boards, and may cause problems with Linux. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-2583xx: define CONFIG_OF_STDOUT_VIA_ALIAS for the MPC837XERDB boardsAnton Vorontsov
This is primarily for the early console support. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: initialize serdes for MPC837XRDB boardsAnton Vorontsov
On the MPC8377ERDB: 2 SATA and 2 PCI-E. On the MPC8378ERDB: 2 PCI-E On the MPC8379ERDB: 4 SATA Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: nand support for MPC837XRDB boardsAnton Vorontsov
2008-03-2583xx: Add Vitesse VSC7385 firmware uploadingTimur Tabi
Update the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB board files to upload the Vitesse VSC7385 firmware. Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET. Cleaned up the board header files to make selecting the VSC7385 easier to control. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-07mpc83xx: make dtb basename file references equal those of linuxKim Phillips
the dts file basenames were updated in linux - this helps avoid inadvertently loading any old dtbs laying around. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16Add support for the MPC837xERDBKim Phillips
MPC837xERDB board support includes: * DDR2 330MHz hardcoded (soldered on the board) * Local Bus NOR Flash * I2C, UART and RTC * eTSEC RGMII (TSEC0 - RTL8211B with MII; * TSEC1 - VSC7385 local bus, hardcoded, requires seperate firmware * load) Signed-off-by: Kevin Lam <kevin.lam@freescale.com> Signed-off-by: Joe D'Abbraccio <joe.d'abbraccio@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
