Modifications to the existing code to support the new fdt command.
8360 and 832x weren't updating their [local-]mac-address
properties. This patch fixes that.
MPC8360E rev2.0 have new spridr,and PVR value,
The MDS board for MPC8360E rev2.0 has 32M bytes Flash and 256M DDR2 DIMM.
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
The patch solves the alignment problem of the local bus access windows to
render accessible the memory bank and PHY registers of UPC 1 (starting at
0xf801 0000). What we actually did was to adjust the sizes of the bus
access windows so that the base address alignment requirement would be met.
Signed-off-by: Chereji Marian <marian.chereji@freescale.com>
Signed-off-by: Gridish Shlomi <gridish@freescale.com>
Signed-off-by: Dave Liu <daveliu@freescale.com>
make 8360 default environment fdt be 8360 (not 8349)
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete
cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files.
Added multiple I2C bus support to fsl_i2c.c.
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx
tree matches the other 8xxx trees.
add ft_pci_setup, OF_CPU, OF_SOC, OF_TBCLK, and
STDOUT_PATH configuration bits to mpc8349emds,
mpc8349itx, and mpc8360emds board code.
redo environment to use bootm with the fdtaddr
for booting ARCH=powerpc kernels by default,
and provide default fdtaddr values.
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
Add support for the Freescale MPC8360EMDS board.
Includes DDR, DUART, Local Bus, PCI.
