rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
move the BRx_* and ORx_* left behind in mpc85xx.h
The same is needed for mpc8xx.h and mpc8260.h (defines are almost
the same, just few differences which needs some attention though).
But the bad news for mpc8xx and mpc8260 is that there are a lot of users
of these defines. So this cleanup I'll leave for the "better times".
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Change all code that conditionally operates on high bat
registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS
instead of the myriad ways this is done now. Define the option
for every config for which high bats are supported (and
enabled by early boot, on parts where they're not always
enabled)
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
this seems as a good compromise between human memory, typing,
and last but not least, to accommodate for current and future kernel bloat.
Acked-by: Dave Liu <daveliu@freescale.com>
With the original value of 1/2 clock cycle delay, the system ran relatively
stable except when we run benchmarks that are intensive users of memory.
When I run samba connected disk with a HDBENCH test, the system locks-up
or reboots sporadically.
Signed-off by: Joe D'Abbraccio <Joe.D'abbraccio@freescale.com>
Update the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB board files to upload
the Vitesse VSC7385 firmware. Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET.
Cleaned up the board header files to make selecting the VSC7385 easier to
control.
clean up the cache config from configs.h of board
Signed-off-by: Dave Liu <daveliu@freescale.com>
convert to using simpler mpc85xx style fdt update code; streamline by
eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm
the old school FLAT_TREE code from 83xx (since the sbc8349 was just
converted over to using libfdt).
Fix the definitions of CFG_ENV_ADDR and CFG_ENV_SECT_SIZE for all of the
currently-defined 83xx boards. This change guarantees that the environment
will be located on the first flash sector after the U-Boot image.
and make some minor corrections to the FDT part of the README.
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether
to update TSEC1's device-tree node, so we need to add it
to all the boards with TSECs. Do this for 83xx and 86xx, too,
since they will eventually do something similar.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The tsec_info structure and array has a "flags" field for each
ethernet controller. This field is the only reason there are
settings. Switch to defining TSECn_FLAGS for each controller
in the config header, and we can greatly simplify the array, and
also simplify the addition of future boards.
this enables libfdt code by default for the
freescale mpc8313erdb, mpc832xemds, mpc8349emds,
mpc8349itx and gp boards.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
Current include/configs/MPC8349ITX.h does contain some support for building
image that will be started from memory (without putting in into flash).
It could be triggered by building with TEXT_BASE set to a low value.
However, this support is incomplete: using of low TEXT_BASE causes
defining configuration macros in inconsistent way, which later leads
to compilation errors. In particular. flash support is being disabled,
but then flash structures get referenced.
This patch fixes this, making it possible to build with low TEXT_BASE.
Signed-Off-By: Nikita Youshchenko <yoush@debian.org>
For all practical u-boot purposes, TSECs don't differ throughout the
mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx.
Define CFG_DDR_SDRAM_CLK_CNTL for the MPC8349E-mITX and MPC8349E-mITX-GP.
This allows ddr->sdram_clk_cntl to be properly initialized. This is necessary
on some ITX boards, notably those with a revision 3.1 CPU.
Also change spd_sdram() in cpu/mpc83xx/spd_sdram.c to not write anything into
ddr->sdram_clk_cntl if CFG_DDR_SDRAM_CLK_CNTL is not defined.
Acked-by: Michael Benedict <MBenedict@twacs.com>
Add support for the MPC8349E-mITX-GP, a stripped-down version of the
MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in
HRCW is 0) for the ITX and a README for the ITX and the ITX-GP.
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete
cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files.
Added multiple I2C bus support to fsl_i2c.c.
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx
tree matches the other 8xxx trees.
add ft_pci_setup, OF_CPU, OF_SOC, OF_TBCLK, and
STDOUT_PATH configuration bits to mpc8349emds,
mpc8349itx, and mpc8360emds board code.
redo environment to use bootm with the fdtaddr
for booting ARCH=powerpc kernels by default,
and provide default fdtaddr values.
MPC8360EMDS
This patch also adds an improved I2C set_speed(), which handles all clock
frequencies.
PREREQUISITE PATCHES:
* This patch can only be applied after the following patches have been applied:
1) DNX#2006092142000015 "Add support for the MPC8349E-mITX 1/2"
2) DNX#2006092142000024 "Add support for the MPC8349E-mITX 2/2"
CHANGELOG:
* For the 8349E-mITX, fix some size values in pci_init_board(), enable
the clock for the 2nd USB board (Linux kernel will hang otherwise),
and fix the CONFIG_BOOTARGS macro.
1) DNX#2006090742000024 "Add support for multiple I2C buses"
2) DNX#2006090742000033 "Multi-bus I2C implementation of MPC834x"
3) DNX#2006091242000041 "Additional MPC8349 support for multibus i2c"
4) DNX#2006091242000078 "Add support for variable flash memory sizes on 83xx systems"
5) DNX#2006091242000069 "Add support for Errata DDR6 on MPC 834x systems"
CHANGELOG:
* Add support for the Freescale MPC8349E-mITX reference design platform.
The second TSEC (Vitesse 7385 switch) is not supported at this time.
