path: root/include/configs/MPC8349EMDS.h
2009-04-01mpc83xx: Set guarded bit on BAT that covers the end of the address spaceScott Wood
The mpc8313erdb board currently sets DBAT6 to cover all of the final 256MiB of address space; however, not all of this space is covered by a device. In particular, flash sits at 0xfe000000-0xfe7fffff, and nothing is mapped at the far end of the address space. In zlib, there is a loop that references p[-1] if p is non-NULL. Under some circumstances, this leads to the CPU speculatively loading from 0xfffffff8 if p is NULL. This leads to a machine check. Signed-off-by: Scott Wood <scottwood@freescale.com> continuation to the remaining mpc83xx boards that suffer from the same problem. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-3083xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-09-24mpc83xx: add h/w flash protection to board configsKim Phillips
the operating system may leave flash in a h/w locked state after writing. This allows u-boot to continue to write flash by enabling h/w unlocking by default. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-08-25MPC8349EMDS: Add PCI Agent (PCISLAVE) supportIra W. Snyder
Add the ability for the MPC8349EMDS to run in PCI Agent mode, acting as a PCI card rather than a host computer. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-08-25MPC8349EMDS: use 83XX_GENERIC_PCI setup codeIra W. Snyder
Change the MPC8349EMDS board to use the generic PCI initialization code for the mpc83xx cpu. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-01Move conditional compilation of MPC8XXX SPI driver to MakefileBen Warren
2008-06-1083xx/85xx: further localbus cleanupsAnton Vorontsov
move the BRx_* and ORx_* left behind in mpc85xx.h The same is needed for mpc8xx.h and mpc8260.h (defines are almost the same, just few differences which needs some attention though). But the bad news for mpc8xx and mpc8260 is that there are a lot of users of these defines. So this cleanup I'll leave for the "better times". Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-05-06mpc83xx: system performance settings for MPC8349EMDS.Lee Nipper
These same settings are used on MPC8349ITX, and improve performance on MPC8349EMDS. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-25mpc83xx: bump loadaddr over fdtaddr to 0x500000Kim Phillips
this seems as a good compromise between human memory, typing, and last but not least, to accommodate for current and future kernel bloat. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-02-12Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-02-12Remove #undef DEBUG from MPC83xx board header filesTimur Tabi
Remove the "#undef DEBUG" line from all Freescale 83xx board header files. The inclusion of this line makes it impossible to enable debug code in other source files, because "#define DEBUG" typically needs to be defined before any header files are included. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-01-29Fix conditional compilation of mpx8xxx_spi driverBen Warren
This driver should only compile if CONFIG_MPC8XXX_SPI is set Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-17codingstyle cleanup for spi driverKim Phillips
..and rm unused CONFIG_FSL_SPI define Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-17Implement hard SPI driver on MPC8349EMDSBen Warren
This patch implements the fsl_spi driver on the MPC8349EMDS evaluation board. This board has an ST M25P40 4Mbit EEPROM on its SPI bus Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10mpc83xx: Remove cache config from config.hDave Liu
clean up the cache config from configs.h of board Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-0883xx: fix CFG_ENV_ADDR and CFG_ENV_SECT_SIZE definitionsTimur Tabi
Fix the definitions of CFG_ENV_ADDR and CFG_ENV_SECT_SIZE for all of the currently-defined 83xx boards. This change guarantees that the environment will be located on the first flash sector after the U-Boot image. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc83xxWolfgang Denk
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-15mpc83xx: enable libfdt by default on freescale boardsKim Phillips
this enables libfdt code by default for the freescale mpc8313erdb, mpc832xemds, mpc8349emds, mpc8349itx and gp boards. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 83xx board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: Fix config of Arbiter, System Priority, and Clock ModeKumar Gala
The config value for: * CFG_ACR_PIPE_DEP * CFG_ACR_RPTCNT * CFG_SPCR_TSEC1EP * CFG_SPCR_TSEC2EP * CFG_SCCR_TSEC1CM * CFG_SCCR_TSEC2CM Were not being used when setting the appropriate register Added: * CFG_SCCR_USBMPHCM * CFG_SCCR_USBDRCM * CFG_SCCR_PCICM * CFG_SCCR_ENCCM To allow full config of the SCCR. Also removed random CFG_SCCR settings in MPC8349EMDS, TQM834x, and sbc8349 that were just bogus. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-03-02mpc83xx: add command line editing by defaultKim Phillips
2007-03-02mpc83xx: Add the cpu and board specific code for MPC8349E rev3.1 MDSXie Xiaobo
MPC8349E rev3.1 have new spridr,and PVR value, The MDS board for MPC8349E rev3.1 has 32M bytes Flash and 256M DDR2 DIMM. Signed-off-by: Xie Xiaobo<X.Xie@freescale.com>
2006-11-03mpc83xx: Update 83xx to use fsl_i2c.cTimur Tabi
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files. Added multiple I2C bus support to fsl_i2c.c. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Replace CFG_IMMRBAR with CFG_IMMRTimur Tabi
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx tree matches the other 8xxx trees. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: add OF_FLAT_TREE bits to 83xx boardsKim Phillips
add ft_pci_setup, OF_CPU, OF_SOC, OF_TBCLK, and STDOUT_PATH configuration bits to mpc8349emds, mpc8349itx, and mpc8360emds board code. redo environment to use bootm with the fdtaddr for booting ARCH=powerpc kernels by default, and provide default fdtaddr values.
2006-11-03Multi-bus I2C implementation of MPC834xBen Warren
Hello, Attached is a patch implementing multiple I2C buses on the MPC834x CPU family and the MPC8349EMDS board in particular. This patch requires Patch 1 (Add support for multiple I2C buses). Testing was performed on a 533MHz board. /*** Note: This patch replaces ticket DNX#2006083042000027 ***/ Signed-off-by: Ben Warren <bwarren@qstreams.com> CHANGELOG: Implemented driver-level code to support two I2C buses on the MPC834x CPU family and the MPC8349EMDS board. Available I2C bus speeds are 50kHz, 100kHz and 400kHz on each bus. regards, Ben
2006-05-10Minor cleanup.LABEL_2006_05_10_1800Wolfgang Denk
2006-04-20Merged MPC8349ADS and MPC8349EMDS ports into MPC8349EMDS port:Kumar Gala
- Removed MPC8349ADS port - Added PCI support to MPC8349ADS - reworked memory map to allow mapping of all regions with BATs Patch by Kumar Gala 20 Apr 2006 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-04-16Some code cleanupWolfgang Denk
2006-03-16Support for DDR with 32-data path. Addotional notes on injectingRafal Jaworowski
multiple-bit errors.
2006-03-16Add command for handling DDR ECC registers on MPC8349EE MDS board.Marian Balakowicz
2006-03-14Add initial support for MPC8349E MDS board.Marian Balakowicz
