There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
some LCRR bits are not documented throughout the 83xx family RMs.
New board porters copying similar board configurations might omit
setting e.g., DBYP since it was not documented in their SoC's RM.
Prevent them bricking their board by retaining power on reset values
in bit fields that the board porter doesn't explicitly configure
via CONFIG_SYS_<registername>_<bitfield> assignments in the board
config file.
also move LCRR assignment to cpu_init_r[am] to help ensure no
transactions are being executed via the local bus while CLKDIV is being
modified.
also start to use i/o accessors.
linux mpc83xx_defconfig kernels are getting bigger, accommodate for
their growth by adjusting default load and fdt addresses.
the former
This patch simply converts the board to the hwconfig infrastructure.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
When enabling NAND support for a board, one must also define
CONFIG_SYS_64BIT_VSPRINTF because this is needed in nand_util.c
for correct output.
Cc: Dave Liu <daveliu@freescale.com>
Cc: Ron Madrid <ron_madrid@sbcglobal.net>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch adds CONFIGs for enabling USB in mpc8315erdb and also
adds usb_phy_type in CONFIG_EXTRA_ENV_SETTINGS. Also revamps its
Copyright.
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Use the standard lowercase "x" capitalization that other Freescale
architectures use for CPU defines to prevent confusion and errors
Use the standard lowercase "xx" capitalization that other Freescale
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Dave Liu <daveliu@freescale.com>
MPC8315ERDB boards features PCI-E x1 and Mini PCI-E x1 ports. Let's
support them.
modify the CAS timings. my understanding is that these
settings decrease various wait times in the DDR interface.
Because these wait times are in clock cycles, and the DDR
clock on the 8315 RDB runs slower than on some other 83xx
platforms, we can dial down these values without a problem,
thereby decreasing the latency of memory a little.
Signed-off-by: Howard Gregory <Greg.Howard@freescale.com>
the operating system may leave flash in a h/w locked state after writing.
This allows u-boot to continue to write flash by enabling h/w unlocking
by default.
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
Freescale ships MPC8315E-RDB boards either with TSEC1 and USB UTMI
support, or without TSEC1 but with USB ULPI PHY support in addition.
With this patch user can specify desired USB PHY.
Also, it seems that we can't distinguish the two boards in software, so
user have to set `mpc8315erdb' environment variable to either 'tsec1'
(TSEC1 enabled) or `ulpi' (board with ULPI PHY, TSEC1 disabled), so that
Linux will not probe for TSEC1.
move the BRx_* and ORx_* left behind in mpc85xx.h
The same is needed for mpc8xx.h and mpc8260.h (defines are almost
the same, just few differences which needs some attention though).
But the bad news for mpc8xx and mpc8260 is that there are a lot of users
of these defines. So this cleanup I'll leave for the "better times".
Change all code that conditionally operates on high bat
registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS
instead of the myriad ways this is done now. Define the option
for every config for which high bats are supported (and
enabled by early boot, on parts where they're not always
enabled)
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
this seems as a good compromise between human memory, typing,
and last but not least, to accommodate for current and future kernel bloat.
Acked-by: Dave Liu <daveliu@freescale.com>
The device trees for these boards describe PCI I/O as starting from
address zero from the device's perspective.
Placing I/O elsewhere may cause problems with certain PCI boards, and may
cause problems with Linux.
The features list:
- Boot from NOR Flash
- DDR2 266MHz hardcoded configuration
- Local bus NOR Flash R/W operation
- I2C, UART, MII and RTC
- eTSEC0/1 support
- PCI host
