path: root/include/configs/MPC8313ERDB_NOR.h
2019-05-21mpc83xx: Get rid of CONFIG_SYS_LBC_*Mario Six
Except for one counter example, CONFIG_SYS_LBC_LBCR always has a value of either 0x00040000 or 0x00000000. CONFIG_SYS_LBC_MRTPR always has the value 0x20000000. CONFIG_SYS_LBC_LSDMR_{1,2,4,5} are not set for any mpc83xx board. CONFIG_SYS_LBC_LSRT is set by one board (to 0x32000000). To simplify the configuration files, hardcode the setting of these values for mpc83xx. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_SDRAM_BASEMario Six
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as CONFIG_SYS_SDRAM_BASE on all existing boards. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_BASEMario Six
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate arbiter config to KconfigMario Six
Migrate the arbiter configuration to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_IMMR to KconfigMario Six
Migrate CONFIG_SYS_IMMR to Kconfig for MPC83xx. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Simplify BR,OR linesMario Six
Re-format all BR,OR #define lines into single lines. This makes them harder to read, but accessible to semi-automatic replacement. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Normalize BR/OR option linesMario Six
All BR/OR option lines should have the same layout to make them easier to migrate to Kconfig. This includes using the same option macros everywhere. The normalize the lines, * replace function macros with their results, and * replace hardcoded hex values with standard macros Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC8313ERDB: Remove CONFIG_MPC8313ERDBMario Six
CONFIG_MPC8313ERDB is unused, and TARGET_MPC8313ERDB_NAND/TARGET_MPC8313ERDB_NOR Kconfig could replace it. Hence, get rid of CONFIG_MPC8313ERDB. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20mpc83xx: Make distinct MPC8313ERDB targetsMario Six
MPC8313ERDB has the option of either enabling NOR or NAND boot in its config file (by commenting out certain #ifdefs). To keep this ability after migrating options to Kconfig, we introduce two MPC8313ERDB configs: one for NOR, and one for NAND. Signed-off-by: Mario Six <mario.six@gdsys.cc>
