CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Newer Linux kernels can overrun the initial memory window used for
booting with their BSS area. When this happens, they overwrite the FDT
and silently fail to boot.
On e300 CPUs, the Linux kernel uses an initial BAT covering the first
256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase
the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value
allowed by Linux. This will allow very large kernels to boot.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
The default partition table matches the .dts files for these boards in
Linux. This allows these partitions to be used by name with U-Boot's
"nand" command.
Some parts that have an Enhanced Local Bus Controller weren't
setting CONFIG_FSL_ELBC. Fix this so we can use this define
properly going forward (currently it's only used if PHYS_64BIT is
set, which meant not all platforms needed to have it set correctly).
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
This patch changed the SICRL_USBDR define to reflect the 4 different bit
settings for this two-bit field. The four different options are '00', '01',
'10', and '11'. This patch also corrects the config file for SIMPC8313 and
MPC8313ERDB for the appropriate fields. This change only affects the MPC8313
cpu.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
before, MPC8349ITX boots u-boot in 4.3sec:
column1 is elapsed time since first message
column2 is elapsed time since previous message
column3 is the message
0.000 0.000: U-Boot 2010.03-00126-gfd4e49c (Apr 11 2010 - 17:25:29) MPC83XX
0.000 0.000:
0.000 0.000: Reset Status:
0.000 0.000:
0.032 0.032: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz
0.032 0.000: Board: Freescale MPC8349E-mITX
0.032 0.000: UPMA: Configured for compact flash
0.032 0.000: I2C: ready
0.061 0.028: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz)
1.516 1.456: FLASH: 16 MB
2.641 1.125: PCI: Bus Dev VenId DevId Class Int
2.652 0.011: 00 10 1095 3114 0180 00
2.652 0.000: PCI: Bus Dev VenId DevId Class Int
2.652 0.000: In: serial
2.652 0.000: Out: serial
2.652 0.000: Err: serial
2.682 0.030: Board revision: 1.0 (PCF8475A)
3.080 0.398: Net: TSEC1: No support for PHY id ffffffff; assuming generic
3.080 0.000: TSEC0, TSEC1
4.300 1.219: IDE: Bus 0: .** Timeout **
after, MPC8349ITX boots u-boot in 3.0sec:
0.010 0.010: U-Boot 2010.03-00127-g4b468cc-dirty (Apr 11 2010 - 17:47:29) MPC83XX
0.010 0.000:
0.010 0.000: Reset Status:
0.010 0.000:
0.017 0.007: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz
0.017 0.000: Board: Freescale MPC8349E-mITX
0.038 0.020: UPMA: Configured for compact flash
0.038 0.000: I2C: ready
0.038 0.000: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz)
0.260 0.222: FLASH: 16 MB
1.390 1.130: PCI: Bus Dev VenId DevId Class Int
1.390 0.000: 00 10 1095 3114 0180 00
1.390 0.000: PCI: Bus Dev VenId DevId Class Int
1.400 0.010: In: serial
1.400 0.000: Out: serial
1.400 0.000: Err: serial
1.400 0.000: Board revision: 1.0 (PCF8475A)
1.832 0.432: Net: TSEC1: No support for PHY id ffffffff; assuming generic
1.832 0.000: TSEC0, TSEC1
3.038 1.205: IDE: Bus 0: .** Timeout **
also tested on these boards (albeit with a less accurate
boottime measurement method):
seconds: before after
8349MDS ~2.6 ~2.2
8360MDS ~2.8 ~2.6
8313RDB ~2.5 ~2.3 #nand boot
837xRDB ~3.1 ~2.3
also tested on an 8323ERDB.
v2: also remove the delayed icache enablement assumption in arch ppc's
board.c, and add a CONFIG_MPC83xx define in the ITX config file for
consistency (even though it was already being defined in 83xx'
config.mk).
because it's convenient.
and avoid e.g., two identical boards from causing random networking
conflicts when hooked up to the same network.
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
some LCRR bits are not documented throughout the 83xx family RMs.
New board porters copying similar board configurations might omit
setting e.g., DBYP since it was not documented in their SoC's RM.
Prevent them bricking their board by retaining power on reset values
in bit fields that the board porter doesn't explicitly configure
via CONFIG_SYS_<registername>_<bitfield> assignments in the board
config file.
also move LCRR assignment to cpu_init_r[am] to help ensure no
transactions are being executed via the local bus while CLKDIV is being
modified.
also start to use i/o accessors.
So that we can set the NAND loader's relocate stack pointer
to the value other than the relocate address + 0x10000.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
linux mpc83xx_defconfig kernels are getting bigger, accommodate for
their growth by adjusting default load and fdt addresses.
the former
Saving the environment leads to overwriting u-boot itself,
bricking boards. Increase u-boot's image size so the environment
base address doesn't end up overlapping u-boot text.
When enabling NAND support for a board, one must also define
CONFIG_SYS_64BIT_VSPRINTF because this is needed in nand_util.c
for correct output.
Cc: Dave Liu <daveliu@freescale.com>
Cc: Ron Madrid <ron_madrid@sbcglobal.net>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Use the standard lowercase "x" capitalization that other Freescale
architectures use for CPU defines to prevent confusion and errors
Use the standard lowercase "xx" capitalization that other Freescale
The following individual I2C commands have been removed: imd, imm, inm,
imw, icrc32, iprobe, iloop, isdram.
The functionality of the individual commands is still available via
the 'i2c' command.
This change only has an impact on those boards which did not have
CONFIG_I2C_CMD_TREE defined.
The mpc8313erdb board currently sets DBAT6 to cover all of the final 256MiB of
address space; however, not all of this space is covered by a device. In
particular, flash sits at 0xfe000000-0xfe7fffff, and nothing is mapped
at the far end of the address space.
In zlib, there is a loop that references p[-1] if p is non-NULL. Under
some circumstances, this leads to the CPU speculatively loading from
0xfffffff8 if p is NULL. This leads to a machine check.
continuation to the remaining mpc83xx boards that suffer from the same problem.
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Currently this is not creating any problem. But it will result
in compilation error when used as below.
printf("CFG_SDRAM_CFG2 - %08x\n", CFG_SDRAM_CFG2);
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
continuation of the theme based on git grep "^#define CFG_.*;$" include/
bootdelay set to -1 'permanently' disables autobooting, even if
bootcmd is specified. Change to a positive value to allow
autobooting when a bootcmd is set.
Reported-by: Coray Tate <Coray.Tate@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
the operating system may leave flash in a h/w locked state after writing.
This allows u-boot to continue to write flash by enabling h/w unlocking
by default.
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
Note that with older board revisions, NAND boot may only work after a
power-on reset, and not after a warm reset. I don't have a newer board
to test on; if you have a board with a 33MHz crystal, please let me know
if it works after a warm reset.
Change all code that conditionally operates on high bat
registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS
instead of the myriad ways this is done now. Define the option
for every config for which high bats are supported (and
enabled by early boot, on parts where they're not always
enabled)
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Change LCRR clock ratio from 2 to 4 to commodate VSC7385.
Correct TSEC1 vs TSEC2 assignment.
Define ETHADDR and ETH1ADDR always.
Signed-off-by: York Sun <yorksun@freescale.com>
this seems as a good compromise between human memory, typing,
and last but not least, to accommodate for current and future kernel bloat.
Acked-by: Dave Liu <daveliu@freescale.com>
Update the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB board files to upload
the Vitesse VSC7385 firmware. Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET.
Cleaned up the board header files to make selecting the VSC7385 easier to
control.
These changes were identified by HighSmith Bill ,Mazzyar and Joseph for
DDR configuration in u-boot code. Some are related to performance, some
affect stability and some correct few basic errors in the current
configuration.
The changes have been tested and found to give better memory latency
figures on MPC8313eRDB.LMBench figures prove it.
The changes are:
- CS0_CONFIG[ AP_n_EN] is changed from 1 to 0
(this may improve performance for application with many read
or write to open pages).
- CS0_CONFIG[ODT_WR_CFG] is currently changed from 100 to
001 (activating all the CS when only one is used may cause
unwanted noise on the system)
- TIMING_CFG_1[ACTTOPRE] is changed from 9clks to 8clks (based on
Tras=45ns)
- TIMING_CFG_1[REFREC] changed from 21 clks to 18clks.
- TIMING_CFG_2[AL] value changed from 0 setting to 1 clk to
comply with the 3 ODT clk requirements)
- TIMING_CFG_2[CPO] was set to a reserved value, changed to RL+3/4.
- TIMING_CFG_2[FOUR_ACT] is changed from 10 clks to 6clks.
- DDR_SDRAM_MODE[AL]changed from 0 to 1.
- DDR_SDRAM_MODE[WRREC] changed from 1 clk to 3 clks.
- DDR_SDRAM_INTERVAL[REFINT] is changed from 0x0320 to 0x0510.
- DDR_SDRAM_INTERVAL[BSTOPRE] is changed from 0x64 to 0x0500.
The patch is based of git://www.denx.de/git/u-boot-mpc83xx.git
The last commit on this tree was 6775c68683a53c7abc778774641aac6f833a2cbf
Signed-off-by: Poonam Aggrwal-b10812 <b10812@freescale.com>
Cc: Bill HighSmith <Bill.Highsmith@freescale.com>
Cc: Razzaz Mazyar <MRazzaz@freescale.com>
Cc: Josep P J <PJ.Joseph@freescale.com>
clean up the cache config from configs.h of board
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
convert to using simpler mpc85xx style fdt update code; streamline by
eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm
the old school FLAT_TREE code from 83xx (since the sbc8349 was just
converted over to using libfdt).
Fix the definitions of CFG_ENV_ADDR and CFG_ENV_SECT_SIZE for all of the
currently-defined 83xx boards. This change guarantees that the environment
will be located on the first flash sector after the U-Boot image.
and make some minor corrections to the FDT part of the README.
