This board is still a non-generic board.
Cc: Rune Torgersen <runet@innovsys.com>
Before this commit, CONFIG_MPC8260 and CONFIG_8260
were used mixed-up.
All boards with mpc8260 cpu defined both of them:
- CONFIG_MPC8260 was defined in board config headers
and include/common.h
- CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk
We do not need to have both of them.
This commit keeps only CONFIG_MPC8260.
This commit does:
- Delete CONFIG_8260 and CONFIG_MPC8260 definition
in config headers and include/common.h
- Rename CONFIG_8260 to CONFIG_MPC8260
in arch/powerpc/cpu/mpc8260/config.mk.
- Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
[trini: Fixup common/cmd_io.c]
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
In the recent dropping of !NET_MULTI code (commit e2a53458a7ab37523304),
I misread the logic in include/net.h. Some of it was used by NET_MULTI
code as glue between the multi/non-multi worlds for cpm2 boards.
Rather than restore the block of code, push the logic to the board config
headers where it all belongs.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
Remove board-specific #ifdefs for calling phy_reset() during
initializtion
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
Fix MPC8266 command line definition so it won't break when new commands
are added to u-boot.
Signed-off-by Rune Torgersen <runet@innovsys.com>
Signed-off-by: Runet Torgersen <runet@innovsys.com>
CONFIG_BOOTP_MASK.
Mostly removed from comments here.
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
Patch by Andrew Dyer, 28 Dec 2004
* Cleanup: fix broken builds
Old, obsolete and duplicated code was cleaned up and replace by the
new partitioning method. There are two possible approaches now:
* define a single, static partition
* use mtdparts command line option and dynamic partitioning
Default is static partitioning.
- Convert the CPM2 based functionality to use new CONFIG_CPM2
option rather than a myriad of CONFIG_MPC8560-like variants.
Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560.
Eliminates the CONFIG_MPC8560 option entirely. Distributes the
new CONFIG_CPM2 option to each 8260 board.
enable SNTP support in some boards.
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
Add 'imgextract' command: extract one part of a multi file image.
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
- Fixes for MPC8266 default config
- Allow eth_loopback_test() on 8260 to use a subset of the FCC's
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
