As the board seems to be unmaintained for some time, lets remove
the support in mainline completely.
Cc: Peter De Schrijver <p2@mind.be>
Recent cleanup actions resulted in a number of config.mk files that
contained only LDSCRIPT definitions. Move these into th respective
board config files and remove the now empty config.mk files.
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Detlev Zundel <dzu@denx.de>
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Detlev Zundel < dzu@denx.de>
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Heiko Schocher<hs@denx.de>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This commit adapts 4xx boards for partial linking with --gc-sections.
Cc: Stefan Roese <sr@denx.de>
Cc: Tirumala Marri <tmarri@apm.com>
Cc: David Updegraff <dave@cray.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Larry Johnson <lrj@acm.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Daniel Poirot <dan.poirot@windriver.com>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
All 4xx board config files don't need the cache definitions anymore.
These are now defined in common headers.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
Old, obsolete and duplicated code was cleaned up and replace by the
new partitioning method. There are two possible approaches now:
* define a single, static partition
* use mtdparts command line option and dynamic partitioning
Default is static partitioning.
Update etags build target
* Improve NetConsole support: add support for broadcast destination
address and buffered input.
* Cleanup compiler warnings for GCC 3.3.x and later
* Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
