These boards have been orphaned for more than 6 months.
New configs:
- CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c
- CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand
Other changes:
- add CONFIG_LIB_RAND to boards configs which needs rand()
- put only one rand.o dependency in lib/Makefile
CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library
(declared in include/common.h):
- void srand(unsigned int seed)
- unsigned int rand(void)
- unsigned int rand_r(unsigned int *seedp)
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Tom Rini <trini@ti.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
CONFIG_SYS_GBL_DATA_SIZE is not used any more.
The size of struct "global_data" is automatically calculated
by asm-offsets. (See lib/asm-offsets.c)
GENERATED_GBL_DATA_SIZE should be used instead of
CONFIG_SYS_GBL_DATA_SIZE.
We do not have to define CONFIG_MPC83xx in board config headers
because it is defined in arch/powerpc/cpu/mpc83xx/config.mk.
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
All these macros are completely unused by any code.
CONFIG_FPGA is not a bitfield anymore.
Reviewed-by: Tom Rini <trini@ti.com>
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Includes board config file, documentation, maintainer and boards.cfg
entries, and board specific files in vendor dir.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
