Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
Current u-boot top of tree builds with warnings/errors for
the following boards:
ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823
RPXClassic debris PN62
following patch solves this.
The environment is the canonical storage location of the mac address, so
we're killing off the global data location and moving everything to
querying the env directly.
Rather than have the common ppc code have board-specific hooks, move the
board_get_enetaddr() function into the board-specific init functions.
CC: Ben Warren <biggerbadderben@gmail.com>
