path: root/include/configs/M54451EVB.h
2017-07-22powerpc: Remove unneccessary #ifdefs in reginfoChristophe Leroy
reginfo command is calling mpc8xx_reginfo(), mpc85xx_reginfo() or mpc86xx_reginfo() based on CONFIG_ symbol. As those 3 functions can't me defined at the same time, let's rename them print_reginfo() to avoid the #ifdefs The name is kept generic as it is not at all dependent on powerpc arch and any other arch could want to also print such information. In addition, as the Makefile compiles cmd/reginfo.c only when CONFIG_CMD_REGINFO is set, there is no need to enclose the U_BOOT_CMD definition inside a #ifdef CONFIG_CMD_REGINFO Lets all remove the #ifdefs around the U_BOOT_CMD as this file is only compiled when CONFIG_CMD_REGINFO is defined Finally, this is a PowerPC-only command, disable it on a number of non-PowerPC platforms. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-28m68k: mcf5445x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf5445x/config.mk. Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf5445x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-05m68k: Add generic board support for MCF547X/8X and MCF5445XAlison Wang
This patch adds generic board support for MCF547X/8X and MCF5445X. It is based on the patch about common generic board support for M68K architecture sent by Angelo. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04ColdFire:Update the env settings for several boards.Jason Jin
Move the environment outside the u-boot for some boards and enlarge the u-boot size in some env settings. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14ColdFire: Update bootargsTsiChung Liew
Add a bootargs for M53017EVB and update bootargs for M54451EVB Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Add DSPI support for MCF5227x and MCF5445xTsiChung Liew
Remove individual CPU specific DSPI driver. Add required feature for the common DSPI driver in cpu_init and in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Update for M54451EVBTsiChung Liew
Update serial boot DRAM's Internal RAM, vector table and DRAM in start.S, serial flash's read status command over SPI and NOR flash. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2008-09-10rename CFG_ENV_IS_IN_SPI_FLASH in CONFIG_ENV_IS_IN_SPI_FLASHJean-Christophe PLAGNIOL-VILLARD
2008-08-28ColdFire: Multiple fixes for MCF5445x platformsTsiChung Liew
Add FEC pin set and mii reset in __mii_init(). Change legacy flash vendor from 2 to AMD LEGACY (0xFFF0), change cfi_offset to 0, and change CFG_FLASH_CFI to CONFIG_FLASH_CFI_LEGACY. Correct M54451EVB and M54455EVB env settings in configuration file. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-14ColdFire: Add M54451EVB platform support for MCF5445xTsiChung Liew
