path: root/include/configs/M54451EVB.h
2018-11-27spi: Zap CONFIG_HARD_SPIJagan Teki
In legacy CONFIG_HARD_SPI initalizing spi_init code, which was removed during dm conversion cleanup. So remove the dead instances of CONFIG_HARD_SPI, and related code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-13spi: Migrate CONFIG_CF_SPI to KconfigTuomas Tynkkynen
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-18m68k: mcf5445x: move early ddr init as board-specificAngelo Dureghello
For certain boot types and sbf, for V4 cpu's, an early ddr/sdram init is required. This patch moves this ddr/sdram early initalization away from start.S (to be board related). Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2017-07-22powerpc: Remove unneccessary #ifdefs in reginfoChristophe Leroy
reginfo command is calling mpc8xx_reginfo(), mpc85xx_reginfo() or mpc86xx_reginfo() based on CONFIG_ symbol. As those 3 functions can't me defined at the same time, let's rename them print_reginfo() to avoid the #ifdefs The name is kept generic as it is not at all dependent on powerpc arch and any other arch could want to also print such information. In addition, as the Makefile compiles cmd/reginfo.c only when CONFIG_CMD_REGINFO is set, there is no need to enclose the U_BOOT_CMD definition inside a #ifdef CONFIG_CMD_REGINFO Lets all remove the #ifdefs around the U_BOOT_CMD as this file is only compiled when CONFIG_CMD_REGINFO is defined Finally, this is a PowerPC-only command, disable it on a number of non-PowerPC platforms. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-28m68k: mcf5445x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf5445x/config.mk. Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf5445x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-05m68k: Add generic board support for MCF547X/8X and MCF5445XAlison Wang
This patch adds generic board support for MCF547X/8X and MCF5445X. It is based on the patch about common generic board support for M68K architecture sent by Angelo. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04ColdFire:Update the env settings for several boards.Jason Jin
Move the environment outside the u-boot for some boards and enlarge the u-boot size in some env settings. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14ColdFire: Update bootargsTsiChung Liew
Add a bootargs for M53017EVB and update bootargs for M54451EVB Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Add DSPI support for MCF5227x and MCF5445xTsiChung Liew
Remove individual CPU specific DSPI driver. Add required feature for the common DSPI driver in cpu_init and in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Update for M54451EVBTsiChung Liew
Update serial boot DRAM's Internal RAM, vector table and DRAM in start.S, serial flash's read status command over SPI and NOR flash. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
