path: root/include/configs/M5373EVB.h
2012-09-20ColdFire: Rename NANDFLASH_SIZE into CONFIG_NANDFLASH_SIZE for MCF537xAlison Wang
This patch fixes the build error for MCF537x. As the NANDFLASH_SIZE is redefined in boards.cfg, it is needed to rename NANDFLASH_SIZE into CONFIG_NANDFLASH_SIZE in include/configs/M5373EVB.h. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04ColdFire:Update the env settings for several boards.Jason Jin
Move the environment outside the u-boot for some boards and enlarge the u-boot size in some env settings. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-17ColdFire: Provide gzip image size V2 & V3 platformsTsiChung Liew
Default gzip bootm size is 8MB. Some platforms require more than 8MB Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
