path: root/include/configs/M5271EVB.h
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-02-06Coldfire: M5271EVB: Board header update (dependencies)Richard Retanubun
Cleanup for M5271EVB: Added clarification on the use of CONFIG_SYS_CLOCK. Modified to use u-boot's HUSH parser. Cleanup on environment settings. Removed compiler warning by defining CONFIG_SYS_CS0_* Dependencies: Added the use of CONFIG_SYS_MCF_SYNCR for clock multiplier. This depends on a patch to include/asm-m68k/m5271.h that defines the multiplier and divider ratios. Removed the definition of CONFIG_SYS_FECI2C. This depends on a patch that removes the use of it in cpu/mcf52x2/cpu_init.c Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2008-08-28ColdFire: Raise uart baudrate to 115200 bpsTsiChung Liew
M5249EVB, M5271EVB, M5272C3, M5275EVB and M5282EVB platforms uart baudrate increase from 19200 to 115200 bps Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-16ColdFire: Update Freescale MCF52x2 platformsTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various M* named board config files.Jon Loeliger
2006-05-17Enable autoboot for M5271EVB board.Marian Balakowicz
2006-05-09Add M5271EVB board support.Marian Balakowicz
