path: root/include/configs/M5253EVBE.h
2009-03-17ColdFire: Provide gzip image size V2 & V3 platformsTsiChung Liew
Default gzip bootm size is 8MB. Some platforms require more than 8MB Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Modules header files cleanupTsiChung Liew
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG, MDHA, SKHA, INTC, and FlexBus structures and definitions in immap_5xxx.h to more unify modules header files. Append DSPI support for m547x_8x. SSI cleanup. Remove USB Host structure from immap_539.h. Apply changes to use FlexBus structures in mcf52x2's cpu_init.c and platform configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-14ColdFire: Raise M5253EVBE uart baudrate to 115200 bpsTsiChung Liew
2007-10-25ColdFire 5253: Assign correct SDRAM sizeTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-18Coding style cleanupStefan Roese
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
