path: root/include/configs/M5249EVB.h
2015-04-23m68k: add architecture-specific u-boot.ldsangelo@sysam.it
Add architecture-specific u-boot.lds and remove all board-specific u-boot.lds. All the .text customization that was board-specific have been moved inside the related include/configs, inside a LDS_BOARD_TEXT define. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf52x2: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf52x2/config.mk. Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf52x2/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2008-11-03ColdFire: Modules header files cleanupTsiChung Liew
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG, MDHA, SKHA, INTC, and FlexBus structures and definitions in immap_5xxx.h to more unify modules header files. Append DSPI support for m547x_8x. SSI cleanup. Remove USB Host structure from immap_539.h. Apply changes to use FlexBus structures in mcf52x2's cpu_init.c and platform configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-28ColdFire: Raise uart baudrate to 115200 bpsTsiChung Liew
M5249EVB, M5271EVB, M5272C3, M5275EVB and M5282EVB platforms uart baudrate increase from 19200 to 115200 bps Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2007-08-18Coding style cleanupStefan Roese
2007-08-16ColdFire: Add M5249EVB platform for MCF52x2TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
