path: root/include/configs/M52277EVB.h
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-07ColdFire: Fix the compile issue for M52277Jason Jin
After commit 327474f854a33b5b7a11c374b0446d1d40d9f673, the M52277EVB_stmicro configuration fail to build. Fix it by moving the env outside the flash and update the lds file. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:disable the NFS define for 52277 board.Jason Jin
There is no network device on ColdFire 52277EVB board.But the default cmd include NFS define which make the build error. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14ColdFire: Add DSPI support for MCF5227x and MCF5445xTsiChung Liew
Remove individual CPU specific DSPI driver. Add required feature for the common DSPI driver in cpu_init and in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Update configuration file to use flash buffer writeTsiChung Liew
Update M52277EVB, M53017EVB and M54455EVB platform configuration file to use flash buffer write Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-03-17ColdFire: Provide gzip image size V2 & V3 platformsTsiChung Liew
Default gzip bootm size is 8MB. Some platforms require more than 8MB Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Add SBF support for M52277EVBTsiChung Liew
Add serial boot support Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-31ColdFire: Define bootdelay in configuration file for M52277EVBTsiChung Liew
Signed-off-by: Matt Wadel <Matt.Waddel@freescale.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
