path: root/include/configs/LANTEC.h
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-11-03Use config_cmd_default.h instead of config_cmd_all.hJean-Christophe PLAGNIOL-VILLARD
2007-08-02Fix build errors and warnings / code cleanup.Wolfgang Denk
2007-07-09include/configs/[H-N]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various [IJKL]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-09-24* Fix PHY address argument passing with mii info commandWolfgang Denk
Patch by Andrew Dyer, 28 Dec 2004 * Cleanup: fix broken builds
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-06-09Patch by Robert Schwebel, 13 May 2004:wdenk
Add 'imgextract' command: extract one part of a multi file image.
2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-04-20Compile fixeswdenk
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-11-11* Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211wdenk
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h
2002-10-31Initial revisionwdenk
