path: root/include/configs/KUP4K.h
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-098xx, kup4k/kup4x: add FDT supportHeiko Schocher
2010-08-098xx, kup4k/kup4x: configuration changes, code cleanupHeiko Schocher
- nfs-options removed - hda->sda changed - mtd parts added - loadaddress changed - cmd-line length increased - lcd stuff removed - code cleanup (use I/O accessors etc.) Signed-off-by: Klaus Heydeck <heydeck@kieback-peter.de>
2008-08-06Fix merge problemsStefan Roese
2007-07-09include/configs/[H-N]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-08Clear up confusion over the CMD_POST and POST_DIAG mess.Jon Loeliger
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-08include/configs: Use new CONFIG_CMD_* in various [IJKL]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-05-12Patch by Klaus Heydeck, 12 May 2004:wdenk
Using external watchdog for KUP4 boards in mpc8xx/cpu.c; load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c; various changes to KUP4 board specific files
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonnière, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2002-12-04Add LED indication for IDE activity on KUP4K boardwdenk
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-05Quick & Dirty fix for log buffer problem when environment is not setwdenk
Trigger watchdog when reading the env - this might take a while. Set debugging baud rate for KUP4K board
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
