files.
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
now handling all 4xx cpu's.
Patch by Stefan Roese, 16 Aug 2005
Second serial port on 440GX now defined as a system device.
Add 'Short Etch' code for Cicada PHY within 440gx_enet.c
Patch by Travis B. Sawyer, 12 Jul 2005
Check return value of malloc in 440gx_enet.c
Patch by Travis B. Sawyer, 18 Jul 2005
