path: root/include/configs/IceCube.h
2010-09-19IceCube.h: update configurationWolfgang Denk
Increase malloc size, enable command line editing and history, enable hush shell. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various [IJKL]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-06-06USB: ohci fixes and cleanup for mpc5xxx and IceCube board configMarkus Klotzbuecher
2007-05-29Merge git://www.denx.de/git/u-boot into 2007_05_15-testingMarkus Klotzbuecher
2007-05-28Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-04-23Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-04-20[RFC PATCH] icecube/lite5200b: fix OF_TBCLK (timebase-frequency) calculationDomen Puncer
G2 core reference manual says decrementer and time base are decreasing/increasing once every 4 bus clock cycles. Lets fix it, so time in Linux won't run twice as fast Signed-off-by: Domen Puncer <domen.puncer@telargo.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2006-11-28[PATCH] Enable the IceCube/lite5200 variants to pass a device tree to Linux.Stefan Roese
This patch adds the code and configuration necessary to boot with an arch/powerpc Linux kernel. Signed-off-by: Grant Likely <grant.likely@gmail.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2006-11-27Fix some endianness issues related to the generic ohci driverMarkus Klotzbuecher
2006-03-29Set SDelay register in the DDR controller for the MPC5200B chip.Rafal Jaworowski
2006-03-17Add support for Lite5200B board.Wolfgang Denk
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2004-09-28Fix problems with CDROM drive as slave device on Lite5200 IDE bus.wdenk
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-04-08* Patch by Mark Jonas: Remove config.tmp files only whenwdenk
unconfiguring the board * Adapt RMU board for bigger flash memory * Test fix for ethernet problems on MPC5200
2004-03-17Patch by Pierre Aubert, 15 Mar 2004:wdenk
Fix buffer overflow in IDE identification
2004-03-14* Patch by Pierre Aubert, 11 Mar 2004:wdenk
- add bitmap command and splash screen support in cfb console - add [optional] origin in the bitmap display command * Patch by Travis Sawyer, 11 Mar 2004: Fix ocotea board early init interrupt setup. * Patch by Thomas Viehweger, 11 Mar 2004: Remove redundand code; add PCI-specific bits to include/mpc8260.h
2004-03-14* Patch by Tolunay Orkun, 5 Mar 2004:wdenk
Fix early board initialization for Cogent CSB272 board * Patch by Ed Okerson, 3 Mar 2004: fix CFI flash writes for little endian systems * Patch by Reinhard Meyer, 01 Mar 2004: generalize USB and IDE support for MPC5200 with according changes to IceCube.h and TOP5200.h add Am29LV256 256 MBit FLASH support for TOP5200 boards add info about USB and IDE to README
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
