- Add support to revA version of PQ27 and PQ27E.
- Reverted MPC8260ADS baudrate back to original 115200
* Patch by Hojin, 17 Sep 2004:
Fix typo in cfi_flash.c
* Patch by Mark Jonas, 09 September 2004:
mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong
error message
* Patch by Mark Jonas, 31 August 2004:
Added option CFG_XLB_PIPELINING to enable XLB pipelining. This
improves FTP performance for MPC5200 systems. Enabled for IceCube
by default.
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
Fix buffer overflow in IDE identification
- add bitmap command and splash screen support in cfb console
- add [optional] origin in the bitmap display command
* Patch by Travis Sawyer, 11 Mar 2004:
Fix ocotea board early init interrupt setup.
* Patch by Thomas Viehweger, 11 Mar 2004:
Remove redundand code; add PCI-specific bits to include/mpc8260.h
Fix early board initialization for Cogent CSB272 board
* Patch by Ed Okerson, 3 Mar 2004:
fix CFI flash writes for little endian systems
* Patch by Reinhard Meyer, 01 Mar 2004:
generalize USB and IDE support for MPC5200 with according
changes to IceCube.h and TOP5200.h
add Am29LV256 256 MBit FLASH support for TOP5200 boards
add info about USB and IDE to README
Fix problems with GCC 3.3.x which changed handling of global
variables explicitly initialized to zero (now in .bss instead of
.data as before).
* Patch by Leon Kukovec, 02 Mar 2004:
add strswab() to fix IDE LBA capacity, firmware and model numbers
on little endian machines
* Patch by Masami Komiya, 02 Mar 2004:
- Remove get_ticks() from NFS code
- Add verification of RPC transaction ID
* Patch by Pierre Aubert, 02 Mar 2004:
cleanup for IDE and USB drivers for MPC5200
add IDE support for MPC5200
* Patch by Masami Komiya, 26 Feb 2004:
add autoload via NFS
* Patch by Stephen Williams
Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses
elsewhere in the source.
NS9750 DevBoard added
* Patch by Pierre AUBERT, 24 Feb 2004
add USB support for MPC5200
* Patch by Steven Scholz, 24 Feb 2004:
- fix MII commands to use values from last command
* Patch by Torsten Demke, 24 Feb 2004:
Add support for the eXalion platform (SPSW-8240, F-30, F-300)
Add support for NFS for file download
* Minor code cleanup
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
* Add new configuration for IceCube board with DDR memory
* Update TRAB memory configurations
* Fix configuration problem with IceCube in LOWBOOT configuration:
environment got embedded, corrupting the image layout.
Add low boot support for MPC5200
* Fix problem with dual PCMCIA support (NSCU)
* Fix MPC5200 I2C initialization function
* Patch by Kyle Harris, 30 Oct 2003:
Fix build errors for ixdp425 board
* Patch by David M. Horn, 29 Oct 2003:
Fixes to build under CYGWIN
* Get IceCube MGT5100 working (again)
go back to 66 MHz for stability
enable watchdog support for all MPC824x boards that have a watchdog
* On MPC5200, restrict FEC to a maximum of 10 Mbps to work around the
"Non-octet Aligned Frame" errors we see at 100 Mbps
* Patch by Sharad Gupta, 14 Sep 2003:
fix SPR numbers for upper BAT register ([ID]BAT[4-7][UL])
various changes to VCMA9 board specific files
* Add I2C support for MGT5100 / MPC5200
add burn-in tests for TRAB board
* Enable instruction cache on MPC5200 board
* Add PCI support for SL8245 board
* Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB)
or 1 x AM29LV652 (two LV065 in one chip = 16 MB);
Run IPB at 133 Mhz; adjust the MII clock frequency accordingly
* Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz)
to allow for more accurate baudrate settings
(error now 0.7% at 115 kbps, instead of 3.5% before)
* Patch by Andreas Mohr, 4 Sep 2003:
Fix a lot of spelling errors
* Fix RAM size detection for RMU board
* Implement "reset" for MGT5100/MPC5200 systems
allow selection of clock frequency as "make" target
* Implement memory autosizing code for IceCube boards
* Configure network port on INCA-IP for autonegotiation
* Fix overflow problem in network timeout code
* Patch by Richard Woodruff, 8 Aug 2003:
Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
* Provide consistent interface to standalone applications to access
the 'global_data' structure
Provide a doc/README.standalone more useful to users/developers.
* Make IceCube MGT5100 FEC driver work
