path: root/include/configs/IP860.h
2010-09-19Cleanup use of CONFIG_SYS_SRAM_BASE and CONFIG_SYS_SRAM_SIZEWolfgang Denk
Traditionally many boards used local definitions for SRAM base address and size (like SRAM_BASE, SRAM_LEN and/or SRAM_SIZE), while the (now) "official" names are CONFIG_SYS_SRAM_BASE and CONFIG_SYS_SRAM_SIZE. The corresponding code in arch/powerpc/lib/board.c was board specific, and has never actually been maintained well. Replace this by feature- specific code and adapt the boards that actually use this. NOTE: there is still a ton of boards using the old #defines, which therefor contain incorrect values in bi_sramstart and bi_sramsize. All respective board maintainers are requested to clean up their respective configurations. Thanks. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2009-09-22ppc: Clean up calling of phy_reset() during initPeter Tyser
Remove board-specific #ifdefs for calling phy_reset() during initializtion Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-03-188xx, icache: enabling ICache not before running from RAMHeiko Schocher
with the new CONFIG_SYS_DELAYED_ICACHE config option, ICache is not enabled before code runs from RAM. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-09include/configs/[H-N]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various [IJKL]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
