path: root/include/configs/HIDDEN_DRAGON.h
2010-11-26WINBOND_83C553: enable only on boards that actually use it.Wolfgang Denk
So far, only the BAB7xx board would call the initialise_w83c553f() function for the WINBOND 83C553 chip, even though some other boards (HIDDEN_DRAGON, Sandpoint8240, Sandpoint8245) enabled it in their board configuration. These boards were also missing other config settings needed for that, which resulted in build errors like this: drivers/pci/libpci.o:(.got2+0x84): undefined reference to `ide_bus_offset' Switch arch/powerpc/lib/board.c to call initialise_w83c553f() not on a per-board base, but when a WINBOND_83C553 in enabled in a configuration (like BAB7xx), and disable it in the boards that had this set so far. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Yusdi Santoso <yusdi_santoso@adaptec.com> Cc: Jim Thompson <jim@musenki.com> Acked-by: Stefan Roese <sr@denx.de>
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-08-13drivers/pci: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/misc: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various H* named board config files.Jon Loeliger
2005-04-03* Patch by Yusdi Santoso, 22 Oct 2004:wdenk
- Add support for HIDDEN_DRAGON board - fix endianess problem in driver/rtl1839.c * Patch by Allen Curtis, 21 Oct 2004: support multiple serial ports
