path: root/include/configs/HH405.h
2009-03-20ppc4xx: Use correct io accessors for esd 405/440 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26ppc4xx: Remove CONFIG_SYS_IGNORE_405_UART_ERRATA_59 from config filesMatthias Fuchs
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59. Either they define or undef it. Because it's not used in any source files this patch removes any references to it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-07-11ppc4xx: Consolidate PPC4xx UIC definesStefan Roese
This 2nd patch now removes all UIC mask bit definition. They should be generated from the vectors by using the UIC_MASK() macro from now on. This way only the vectors need to get defined for new PPC's. Also only the really used interrupt vectors are now defined. This makes definitions for new PPC versions easier and less error prone. Another part of this patch is that the 4xx emac driver got a little cleanup, since now the usage of the interrupts is clearer. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-15NAND: Add CFG_NAND_QUIET optionMatthias Fuchs
This config option sets the default for the progress information output behavior that can also be configured through the 'quiet' environment variable. The legacy NAND code does not print the current progress info on the console. So this option is for backward compatibility for units that are in the field and where setting the quiet variable is not an option. With CFG_NAND_QUIET set to '1' the console progress info is turned off. This can still be overwritten through the environment variable. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Migrate esd 405EP boards to new NAND subsystem -cleanup -use correct io accessors (in/out_be32()) Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-07-08include/configs: Use new CONFIG_CMD_* in various H* named board config files.Jon Loeliger
2006-03-06Merge the new NAND code (testing-NAND brach); see doc/README.nandWolfgang Denk
Rewrite of NAND code based on what is in 2.6.12 Linux kernel Patch by Ladislav Michl, 29 Jun 2005 [Merge with /home/tur/nand/u-boot]
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-07Various changes to esd HH405 board specific filesStefan Roese
Patch by Matthias Fuchs, 07 Feb 2006
2005-10-08Fix gzip bmp support (test if malloc fails, warning when truncated).Stefan Roese
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board. Patch by Stefan Roese, 08 Oct 2005
2005-09-30Fix problem with SM501 init on HH405 board.Stefan Roese
Patch by Stefan Roese, 30 Sep 2005
2005-09-22Add SM501 support to HH405 board.Stefan Roese
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP). Add support for eeprom write-enable (CFG_EEPROM_WREN). Patch by Stefan Roese, 22 Sep 2005
2004-12-16esd config files updatedstroese
