2005-04-02 | Fix problems with SNTP support; | wdenk | |
enable SNTP support in some boards. | |||
2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2002-11-05 | * Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120 | wdenk | |
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board |
