2005-09-23 | Cleanup (PPC4xx is AMCC now) | Wolfgang Denk | |
2005-08-12 | esd WUH405 and DU405 board updated | Stefan Roese | |
Patch by Matthias Fuchs, 27 Jul 2005 | |||
2004-12-16 | esd config files updated | stroese | |
2004-01-20 | * The PS/2 mux on the BMS2003 board needs 450 ms after power on | wdenk | |
before we can access it; add delay in case we are faster (with no CF card inserted) * Cleanup of some init functions * Make sure SCC Ethernet is always stopped by the time we boot Linux to avoid Linux crashes by early packets coming in. * Accelerate flash accesses on LWMON board by using buffered writes | |||
2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-02-14 | Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY). | stroese | |
2002-11-03 | Initial revision | wdenk | |
