path: root/include/configs/DP405.h
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup part 2, mostly PPC405 relatedStefan Roese
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from DP405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on DP405 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Some unused featues have been removed therefore. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26ppc4xx: Remove CONFIG_SYS_IGNORE_405_UART_ERRATA_59 from config filesMatthias Fuchs
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59. Either they define or undef it. Because it's not used in any source files this patch removes any references to it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various D* named board config files.Jon Loeliger
2004-12-16esd config files updatedstroese
2003-09-12New board config file added.stroese
