path: root/include/configs/DP405.h
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various D* named board config files.Jon Loeliger
2004-12-16esd config files updatedstroese
2003-09-12New board config file added.stroese
