path: root/include/configs/DB64460.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-09include/configs/[A-G]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various D* named board config files.Jon Loeliger
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
