2004-01-20 | * The PS/2 mux on the BMS2003 board needs 450 ms after power on | wdenk | |
before we can access it; add delay in case we are faster (with no CF card inserted) * Cleanup of some init functions * Make sure SCC Ethernet is always stopped by the time we boot Linux to avoid Linux crashes by early packets coming in. * Accelerate flash accesses on LWMON board by using buffered writes | |||
2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-06-24 | - Remove EEPROM command. | stroese | |
2002-08-19 | Initial revision | wdenk | |
