path: root/include/configs/CPCI405AB.h
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-09include/configs/[A-G]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Remove unused CFG_NAND_LEGACY define These boards to not have NAND. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-07-07include/configs: Use new CONFIG_CMD_* in various C* named board config files.Jon Loeliger
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-25ppc4xx: Maintenance patch for esd's CPCI405 derivatsMatthias Fuchs
-add pci_pre_init() for pci interrupt fixup code -disable phy sleep mode via reset_phy() function -use correct io accessors -cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-01-18PMC405 and CPCI405: Moved configuration of pci resources into config file.Stefan Roese
PMC405 and CPCI2DP: Added firmware download and booting via pci. Patch by Matthias Fuchs, 20 Dec 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-12-16esd config files updatedstroese
2003-09-12Update configuration.stroese
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-06-24- Add ping support.stroese
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
2003-05-23CPCI405AB (special version of esd CPCI405) board added.stroese
