path: root/include/configs/CPCI4052.h
2009-01-26ppc4xx: Remove CONFIG_SYS_IGNORE_405_UART_ERRATA_59 from config filesMatthias Fuchs
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59. Either they define or undef it. Because it's not used in any source files this patch removes any references to it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-14ppc4xx: Add loadpci command to esd's CPCI4052 and CPCI405AB boardsMatthias Fuchs
This patch adds esd's loadpci BSP command to CPCI4052 and CPCI405AB board. This requires CONFIG_CMD_BSP and CONFIG_PRAM. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-09-08ppc4xx: Update CPCI405(AB) configurationMatthias Fuchs
This patch add FDT support and command line editing capabilities for CPCI405 and CPCI405AB boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Cleanup CPCI405 variant's config fileMatthias Fuchs
This patch removes some dead code from CPCI405 board's config files. JFFS2 support is also removed. It's not used and CPCI4052 does not build anymore without some size reduction. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-09include/configs/[A-G]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Remove unused CFG_NAND_LEGACY define These boards to not have NAND. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-07-07include/configs: Use new CONFIG_CMD_* in various C* named board config files.Jon Loeliger
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-25ppc4xx: Maintenance patch for esd's CPCI405 derivatsMatthias Fuchs
-add pci_pre_init() for pci interrupt fixup code -disable phy sleep mode via reset_phy() function -use correct io accessors -cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-01-18PMC405 and CPCI405: Moved configuration of pci resources into config file.Stefan Roese
PMC405 and CPCI2DP: Added firmware download and booting via pci. Patch by Matthias Fuchs, 20 Dec 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-12-16esd config files updatedstroese
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-06-24- Add ping support.stroese
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
2003-05-23DHCP support added.stroese
2003-04-04U-Boot version environment variable "ver" added (CONFIG_VERSION_VARIABLE).stroese
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-20CPCI4052 update (support for revision 3).stroese
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
