We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
We do not have to define CONFIG_4xx in board config headers
because it is defined in arch/powerpc/cpu/ppc4xx/config.mk.
include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx".
I believe it is a typo because "CONFIG_4x" is not used at all
in other files.
So, I also deleted "CONFIG_4x" in include/configs/JSE.h.
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
This commit adapts 4xx boards for partial linking with --gc-sections.
Cc: Tirumala Marri <tmarri@apm.com>
Cc: David Updegraff <dave@cray.com>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Larry Johnson <lrj@acm.org>
Cc: Peter De Schrijver <p2@mind.be>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Daniel Poirot <dan.poirot@windriver.com>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This patch moves the PPC4xx specific I2C device driver into the I2C
drivers directory. All 4xx config headers are updated to include this
driver.
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59.
Either they define or undef it. Because it's not used in any source
files this patch removes any references to it.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
All 4xx board config files don't need the cache definitions anymore.
These are now defined in common headers.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
PMC405 and CPCI2DP: Added firmware download and booting via pci.
Patch by Matthias Fuchs, 20 Dec 2005
Add support for error LED.
Patch by Matthias Fuchs, 07 Nov 2005
Patch by Matthias Fuchs, 22 Sep 2005
