CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
Update image size after addition of new environment handling.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch moves the PPC4xx specific I2C device driver into the I2C
drivers directory. All 4xx config headers are updated to include this
driver.
All 4xx board config files don't need the cache definitions anymore.
These are now defined in common headers.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
