path: root/include/configs/CANBT.h
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-06Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various C* named board config files.Jon Loeliger
2002-09-18Initial revisionwdenk
