path: root/include/configs/C29XPCIE.h
2014-12-05powerpc/c29xpcie: Enable configs to use generic board codeChunhe Lan
Add configs: o CONFIG_SYS_GENERIC_BOARD o CONFIG_DISPLAY_BOARDINFO in C29XPCIE config header file to use U-boot generic board code. Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Add hash command in freescale platformsRuchika Gupta
Enable CAAM in platforms supporting the hardware block. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-22powerpc/ifc: fix invalid CSn FTIM2.TCH settingShaohui Xie
On some platforms, CSn FTIM2.TCH is set to zero which is invalid, an invalid hold time makes DUT timing variances, whether it works or not on luck. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot sizePrabhakar Kushwaha
U-boot binary size has been increased from 512KB to 768KB. So update CONFIG_SYS_MONITOR_LEN to reflect the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-21powerpc/c29xpcie: 8k page size NAND boot support base on TPL/SPLPo Liu
Using the TPL/SPL method to booting from 8k page NAND flash. - Add 256kB size SRAM tlb for second step booting; - Add spl.c for TPL image boot; - Add spl_minimal.c for minimal SPL image; - Add C29XPCIE_NAND configure; - Modify C29XPCIE.h for nand config and enviroment; Signed-off-by: Po Liu <Po.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-12-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-21board/c29xpcie: Add support of 8K page size NAND flashPrabhakar Kushwaha
Defines constants required to support 8K page size NAND flash. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-24powerpc/c29xpcie: add DDR ECC on off config settingPo Liu
c29xpcie REV_A board DDR ECC chip has bad impedance in hardware, force that kind of board to be DDR ECC off when booting. Other version board config ECC on/off by hwconfig=fsl_ddr:ecc=on in uboot enviroment. Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc:c29xpcie: make ifc timing parameter flexiblePo Liu
This patch re-config the NOR flash timing parameters which could make the ifc timing more flexible for NOR flash. The new parameters could fix the problem of hanging at "Flash:" occasionally when booting the board. Signed-off-by: Po Liu <Po.Liu@freescale.com>
2013-08-12powerpc/mpc85xx: Cleanup license header in source filesYork Sun
Fix the license header introduced by the following patches Add TWR-P10xx board support Add T4240EMU target IDT8T49N222A configuration code Add C29x SoC support Add support for C29XPCIE board Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/c29xpcie: add support for C29XPCIE boardMingkai Hu
C29XPCIE board is a series of Freescale PCIe add-in cards to perform as public key crypto accelerator or secure key management module. It includes C293PCIE board, C293PCIE board and C291PCIE board. - 512KB platform SRAM in addition to 512K L2 Cache/SRAM - 512MB soldered DDR3 32bit memory - CPLD System Logic - 64MB x16 NOR flash and 4GB x8 NAND flash - 16MB SPI flash Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Singed-off-by: Po Liu <Po.Liu@freescale.com> [yorksun: Fixup include/configs/C29XPCIE.h] Signed-off-by: York Sun <yorksun@freescale.com>
