Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Move this option to Kconfig and tidy up existing uses.
At present TPL uses the same options as SPL support. In a few cases the board
config enables or disables the SPL options depending on whether
CONFIG_TPL_BUILD is defined.
With the move to Kconfig, options are determined for the whole build and
(without a hack like an #undef in a header file) cannot be controlled in this
way.
Create new TPL options for these and update users. This will allow Kconfig
conversion to proceed for these boards.
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so
that it is always available to the build system. Otherwise we can run
into cases where we have inconsistent sizes of certain attributes.
Ravi Babu reported offset mismatch of struct dwc3 across files since
commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t").
Since the commit, resource_addr_t points to phys_addr_t, whose size
is dependent on CONFIG_PHYS_64BIT for ARM architecture.
I tried my best to use "select" where possible (for example, ARMv8
architecture) because I think this kind of option is generally user-
unconfigurable. However, I see some of PowerPC boards have 36BIT
defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the
defconfigs for such boards.
CONFIG_36BIT is no longer referenced, so all of the defines were
removed from CONFIG_SYS_EXTRA_OPTIONS.
Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t")
Reported-by: Ravi Babu <ravibabu@ti.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is
greater than 12 MiB, which is quite common with modern kernels and
multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under
the ramdiskaddr on most targets.
Signed-off-by: Scott Wood <oss@buserror.net>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
CONFIG_SYS_INIT_RAM_SIZE may be used out of the board header file.
Some boards use CONFIG_SYS_INIT_RAM_END for the same purpose. To
unify the macros, use CONFIG_SYS_INIT_RAM_SIZE for all.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Mario Six <mario.six@gdsys.cc>
Acked-by: Anatolij Gustschin <agust@denx.de>
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
This option only complicates the code unnecessarily, just use
CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are
only five arguments to eeprom {read/write} if this is defined.
If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all
six arguments.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
This config option isn't used anywhere at all. Remove all places that
define/enable the option.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed
from the configs.
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some
time and a more generic method of NAND verification now exists in U-Boot.
Tested-by: Heiko Schocher <hs@denx.de>
Acked-by: Heiko Schocher <hs@denx.de>
Add NOR and SPI flash secure boot target for C29XPCIE board.
Signed-off-by: Po Liu <Po.Liu@freescale.com>
Signed-off-by: Mingkai.Hu <Mingkai.Hu@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Add configs:
o CONFIG_SYS_GENERIC_BOARD
o CONFIG_DISPLAY_BOARDINFO
in C29XPCIE config header file to use U-boot generic
board code.
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Enable CAAM in platforms supporting the hardware block.
Hash command enabled along with hardware accelerated support for
SHA-1 and SHA-256 for platforms which have CAAM block.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
On some platforms, CSn FTIM2.TCH is set to zero which is invalid,
an invalid hold time makes DUT timing variances, whether it works
or not on luck.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
U-boot binary size has been increased from 512KB to 768KB.
So update CONFIG_SYS_MONITOR_LEN to reflect the same.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk
because all target boards with mpc85xx cpu define it.
u-boot binary size for Freescale mpc85xx platforms is 512KB.
This has been reached to upper limit for some of the platforms causig
linker error.
So, Increase the u-boot binary size to 768KB.
Signed-off-by: York Sun <yorksun@freescale.com>
Using the TPL/SPL method to booting from 8k page NAND flash.
- Add 256kB size SRAM tlb for second step booting;
- Add spl.c for TPL image boot;
- Add spl_minimal.c for minimal SPL image;
- Add C29XPCIE_NAND configure;
- Modify C29XPCIE.h for nand config and enviroment;
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Defines constants required to support 8K page size NAND flash.
