path: root/include/configs/BSC9132QDS.h
2013-08-09board/bsc9132qds: Add DSP side tlb and lawsPriyanka Jain
BSC9132QDS is a Freescale Reference Design Board for BSC9132 SoC which is a integrated device that contains two powerpc e500v2 cores and two DSP starcores. To support DSP starcore -Creating LAW and TLB for DSP-CCSR space. -Creating LAW for DSP-core subsystem M2 and M3 memory -Creating LAW for 1GB DDR which is connected exclusively to DSP-cores Signed-off-by: Manish Jaggi <manish.jaggi@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-20board/bsc9132qds:Add NAND boot support using new SPL formatPrabhakar Kushwaha
- Add NAND boot target - defines constants - Add spl_minimal.c to initialise DDR - update TLB, LAW entries as per NAND boot Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-01-30powerpc/85xx: Add BSC9132QDS supportPrabhakar Kushwaha
BSC9132QDS is a Freescale reference design board for BSC9132 SoC. BSC9132 SOC is an integrated device that targets the evolving Microcell, Picocell, and Enterprise-Femto base station market subsegments. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. BSC9132QDS Overview -------------------- 2Gbyte DDR3 (on board DDR), Dual Ranki 32Mbyte 16bit NOR flash 128Mbyte 2K page size NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory SD slot USB-ULPI eTSEC1: Connected to SGMII PHY eTSEC2: Connected to SGMII PHY PCIe CPRI SerDes I2C RTC DUART interface: supports one UARTs up to 115200 bps for console display Apart from the above it also consists various peripherals to support DSP functionalities. This patch adds support for mainly Power side functionalities and peripherals Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
