path: root/include/configs/BSC9132QDS.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-15spl: move FDT_FIXUP_PARTITIONS to KconfigHeiko Schocher
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-07-21powerpc/85xx: Increase fdt addressScott Wood
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is greater than 12 MiB, which is quite common with modern kernels and multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under the ramdiskaddr on most targets. Signed-off-by: Scott Wood <oss@buserror.net> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-03include/configs: Numerous typo fixes: "controler" -> "controller".Robert P. J. Day
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-08powerpc: Replace CONFIG_SYS_INIT_RAM_END with CONFIG_SYS_INIT_RAM_SIZEYork Sun
CONFIG_SYS_INIT_RAM_SIZE may be used out of the board header file. Some boards use CONFIG_SYS_INIT_RAM_END for the same purpose. To unify the macros, use CONFIG_SYS_INIT_RAM_SIZE for all. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mario Six <mario.six@gdsys.cc> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-27secure_boot: include/configs: move definition of CONFIG_CMD_BLOBAneesh Bansal
CONFIG_CMD_BLOB must be defined in case of Secure Boot. It was earlier defined in all config files. The definition has been moved to a common file which is included by all configs. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-16powerpc/913x: Add config flag for bootdelayharninder rai
CONFIG_BOOTDELAY is missing from board header file. Add this macro to enable counting down of auto boot. Signed-off-by: Harninder Rai <harninder.rai@freescale.com> [York Sun: Add commit message] Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-15powerpc/bsc913x: Convert to use generic board codeharninder rai
Signed-off-by: Harninder Rai <harninder.rai@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14powerpc/BSC9132QDS: Enable creation of dynamic partition for NAND and NORAshish Kumar
* fdt_fixup_mtdparts is called from ft_board_setup * run "mtdparts default" to create NAND, NOR partition on uboot * Use mtdparts to create partitions dynamically rather than using static partitions in device tree Signed-off-by: Ashish Kumar <Ashish.Kumar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Enable blob command in freescale platformsRuchika Gupta
Enable blob commands for platforms having SEC 4.0 or greater for secure boot scenarios Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Add hash command in freescale platformsRuchika Gupta
Enable CAAM in platforms supporting the hardware block. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-22powerpc/ifc: fix invalid CSn FTIM2.TCH settingShaohui Xie
On some platforms, CSn FTIM2.TCH is set to zero which is invalid, an invalid hold time makes DUT timing variances, whether it works or not on luck. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16powerpc/mpc85xx: SECURE BOOT- corrected CSPR settings for BSC9132QDS NANDAneesh Bansal
In case of secure boot from NAND, CSPR and FTIM settings are same as non-secure NAND boot. CSPR0 is configured as NAND and CSPR1 is configured as NOR. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot sizePrabhakar Kushwaha
U-boot binary size has been increased from 512KB to 768KB. So update CONFIG_SYS_MONITOR_LEN to reflect the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx: SECURE BOOT- Add NAND secure boot target for BSC9132QDSAneesh Bansal
In case of secure boot from NAND, the DDR is initialized by the BootROM using the config words (CF_WORDS) in the CF_HEADER and u-boot image is copied from NAND to DDR by the BootROM. So, CONFIG_SYS_RAMBOOT has been defined for Secure Boot from NAND Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx: SECURE BOOT- Add secure boot target for BSC9132QDSAneesh Bansal
Add NOR, SPI and SD secure boot targets for BSC9132QDS. Changes: - Debug TLB entry is not required for Secure Boot Target. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-02board/freescale:Remove use of CONFIG_SPL_NAND_MINIMALPrabhakar Kushwaha
CONFIG_SPL_NAND_MINIMAL should not be used as it was defined for temporary review purpose. So, use CONFIG_SPL_NAND_BOOT config. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
