path: root/include/configs/BSC9131RDB.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-16board/bsc9131rdb: Update IFC timings for NAND flashPrabhakar Kushwaha
Current IFC timings for NAND flash are not able to support existing K9F1G08U0B and new K9F1G08U0D flash. so Update the timings to support both. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-20board/bsc9131rdb: Update default boot environment settingsPriyanka Jain
BSC9131RDB has 1GB DDR. Out of this, only 880MB is passed on to Linux via bootm_size. Remaining -16MB is reserved for PowerPC-DSP shared control area -128MB is reserved for DSP private area. Also 256MB, out of this 880MB is required for data communication between PowerPC and DSP core. For this bootargs are modified to pass parameter to create 1 hugetlb page of 256MB via default_hugepagesz, hugepagesz and hugepages Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20board/bsc9131rdb: Add DSP side tlb and lawsPriyanka Jain
BSC9131RDB is a Freescale Reference Design Board for BSC9131 SoC which is a integrated device that contains one powerpc e500v2 core and one DSP starcore. To support DSP starcore -Creating LAW and TLB for DSP-CCSR space. -Creating LAW for DSP-core subsystem M2 memory Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20board/bsc9131rdb: Add targets for Sysclk 100MHzPriyanka Jain
BSC9131RDB supports Sysclk -66MHz if jumper J16 is close (default state) -100MHz if jumper J16 is open Add targets -BSC9131RDB_NAND_SYSCLK100 : for NAND boot at Sysclk 100MHz -BSC9131RDB_SPIFLASH_SYSCLK100: for SPI boot at Sysclk 100MHz Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20board/bsc9131rdb:Add NAND boot support using new SPL formatPrabhakar Kushwaha
- Add NAND boot target - defines constants - Add spl_minimal.c to initialise DDR - update TLB entries as per NAND boot Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-06powerpc/mpc85xx:Add BSC9131 RDB SupportPrabhakar Kushwaha
BSC9131RDB is a Freescale reference design board for BSC9131 SoC. BSC9131 SOC is an integrated device that targets Femto base station market. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements BSC9131RDB Overview ----------------- -1Gbyte DDR3 (on board DDR) -128Mbyte 2K page size NAND Flash -256 Kbit M24256 I2C EEPROM -128 Mbit SPI Flash memory -USB-ULPI -eTSEC1: Connected to RGMII PHY -eTSEC2: Connected to RGMII PHY -DUART interface: supports one UARTs up to 115200 bps for console display Apart from the above it also consists various peripherals to support DSP functionalities. This patch adds support for mainly Power side functionalities and peripherals Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Akhil Goyal <Akhil.Goyal@freescale.com> Signed-off-by: Rajan Srivastava <rajan.srivastava@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
