path: root/include/configs/BC3450.h
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-08-06Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08Clear up confusion over the CMD_POST and POST_DIAG mess.Jon Loeliger
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-07include/configs: Use new CONFIG_CMD_* in various B* named board config files.Jon Loeliger
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2006-05-03Coding Style cleanupWolfgang Denk
2006-04-21Add support for BC3450 boarddzu@denx.de
Signed-off-by: dzu@denx.de <dzu@denx.de>
