path: root/include/configs/BAB7xx.h
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/pci: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/misc: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2007-08-06Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-09include/configs/[A-G]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various B* named board config files.Jon Loeliger
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
