path: root/include/configs/B4860QDS.h
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-21powerpc/85xx: Increase fdt addressScott Wood
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is greater than 12 MiB, which is quite common with modern kernels and multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under the ramdiskaddr on most targets. Signed-off-by: Scott Wood <oss@buserror.net> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-03include/configs: Numerous typo fixes: "controler" -> "controller".Robert P. J. Day
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-27secure_boot: include/configs: move definition of CONFIG_CMD_BLOBAneesh Bansal
CONFIG_CMD_BLOB must be defined in case of Secure Boot. It was earlier defined in all config files. The definition has been moved to a common file which is included by all configs. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-01powerpc: configs: Fix init_ram physical address for several boardsYork Sun
For e6500 and e5500 SoCs, it was intended to put init_ram address in ccsr reserved space. It is no longer true since SerDes module took the space. Move it to another reserved space at CCSR + 0x03c000. Signed-off-by: York Sun <yorksun@freescale.com>
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-12-15mpc85xx: inhibit qman and bman portals by defaultJeffrey Ladouceur
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is required when supporting power management. Signed-off-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/b4860qds: add workaround for XFIShaohui Xie
XFI does not work stable on current board, it's due to heat sink issue, to make it work stable the board needs additional heat sink, enable two XFI lanes only. Right now we do not have such an erratum for the issue, so use a define CONFIG_SYS_FSL_B4860QDS_XFI_ERR to identify it. The workaround will only be used in XFI protocols and only if the hwconfig indicates that XFI is prefered. A new VSC3308 config function is used instead of re-use the original function, to avoid making the function complex and ugly. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05B4860QDS: SGMII related updatesShaveta Leekha
- Enable SGMII support for 0x8d Serdes 2 protocol. - Correct Phy address for DTSECx for 0x8d/0xb2 Serdes 2 protocol. - Updated debug statement - Add Alternate LC VCO protocols(0x8d-->0x8c, 0xb2-->0xb1) - Rename onboard PHY address defines for more readability - Add these new Defines in B4860QDS.h file Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Enable blob command in freescale platformsRuchika Gupta
Enable blob commands for platforms having SEC 4.0 or greater for secure boot scenarios Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Add hash command in freescale platformsRuchika Gupta
Enable CAAM in platforms supporting the hardware block. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24B4860QDS: Enable mac command supportShaveta Leekha
One of the I2C EEPROM is used to store/save and edit mac addresses of ports. this patch add required CONFIG to support the same Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
2014-09-24powerpc/b4860: Updated default hwconfig to enable only cpc2Shaveta Leekha
CPC1 is not being enabled by default as powerpc is supposed to use only CPC2. Though by editing hwconfig en_cpc option, CPC1 can also be enabled. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-22powerpc/ifc: fix invalid CSn FTIM2.TCH settingShaohui Xie
On some platforms, CSn FTIM2.TCH is set to zero which is invalid, an invalid hold time makes DUT timing variances, whether it works or not on luck. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16powerpc/srio-pcie-boot: Adjust addresses for SRIO/PCIE bootLiu Gang
The new 768KB u-boot image size requires changes for SRIO/PCIE boot. These addresses need to be updated to appropriate locations. The updated addresses are used to configure the SRIO/PCIE inbound windows for the boot, and they must be aligned with the window size based on the SRIO/PCIE modules requirement. So for the 768KB u-boot image, the inbound window cannot be set with 0xfff40000 base address and 0xc0000 size, it should be extended to 1MB size and the base address can be aligned with the size. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16mpc85xx: configs: remove c=ffe from default environmentKim Phillips
AFAICT, c=ffe does nothing and was a typo from the original commit d17123696c6180ac8b74fbd318bf14652623e982 "powerpc/p4080: Add support for the P4080DS board" and just kept on getting duplicated in subsequently added board config files. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Edward Swarthout <ed.swarthout@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-13powerpc/freescale: Convert selected boards to generic board architectureYork Sun
This patch converts the following boards to use generic board: MPC8536DS, MPC8572DS, MPC8641HPCN, p1_p2_rdb_pc, corenet_ds, t4qds, B4860QDS. It has been tested on NOR boot on MPC8536DS, MPC8572DS, P1021RDB, P4080DS, P5020DS, P5040DS, P3041DS, T4240QDS, B4860QDS. Signed-off-by: York Sun <yorksun@freescale.com> CC: Ying Zhang <b40530@freescale.com> CC: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Haijun.Zhang <Haijun.Zhang@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Shaohui Xie <Shaohui.Xie@freescale.com>
2014-05-13board/b4qds: VID supportShaveta Leekha
The fuse status register provides the values from on-chip voltage ID efuses programmed at the factory. These values define the voltage requirements for the chip. u-boot reads FUSESR and translates the values into the appropriate commands to set the voltage output value of an external voltage regulator. B4860QDS has a PowerOne ZM7300 programmable digital Power Manager which is programmed as per the value read from the fuses. Reference for this code is taken from t4qds VID implementation. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
