path: root/include/configs/B2.h
2009-03-29s3c44b0: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-29s3c44b0: move rtc driver to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
2009-03-29s3c44b0: move i2c driver to drivers/i2cJean-Christophe PLAGNIOL-VILLARD
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2007-07-09include/configs/[A-G]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various B* named board config files.Jon Loeliger
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
