path: root/include/configs/ATUM8548.h
2011-01-14powerpc/85xx: Removed support for ATUM8548 boardKumar Gala
The ATUM8548 board is no longer maintained and thus we are removing support for it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Clean up ATUM8548 PCI setup codeKumar Gala
Use new fsl_pci_init_port() that reduces amount of duplicated code in the board ports, use IO accessors and clean up printing of status info. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove unused CONFIG_CLEAR_LAW0 definesPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
2008-10-2485xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-08-27FSL DDR: Convert atum8548 to new DDR code.Kumar Gala
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Convert ATUM8548 to new TLB setupKumar Gala
2008-01-1685xx: convert remaining 85xx boards over to use new LAW init codeKumar Gala
Converted ATUM8548, MPC8568 MDS, MPC8540 EVAL, and TQM85xx boards over to use new LAW init code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Remove cache config from ATUM8548 and sbc8548 configsAndy Fleming
These boards weren't updated by Kumar's config patch because they weren't in the tree, yet. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-01-09mpc85xx: Add support for ATUM8548 (updated)robert lazarski
Add support for Instituto Atlantico's ATUM8548 board Signed-off-by: robert lazarski <robertlazarski@gmail.com>
