path: root/include/configs/ADCIOP.h
2012-10-15ppc4xx: Remove IOP480 supportStefan Roese
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2 boards that are not actively maintained, lets remove support for it completely. This way the ppc4xx code will get a bit cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Marek Vasut <marex@denx.de>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[A-I]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various A* named board config files.Jon Loeliger
Since ADS860.h includes "board/fads/fads.h" with ramifications on the CONFIG_COMMAND treatment, it too has to be adjusted to exclude already configured commands in this same commit. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2004-12-16esd config files updatedstroese
2002-08-19Initial revisionwdenk
