path: root/include/configs/10m50_devboard.h
2015-12-19nios2: Soup up the shell experienceMarek Vasut
Enable command auto completion and enable $version variable. This makes working with U-Boot far more enjoyable. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-19nios2: Preconfigure $loadaddr variableMarek Vasut
Preset the $loadaddr environment variable to some sane default, let's say half of the RAM. This variable is where the kernel is loaded using all sorts of .*load commands, so it's convenient to have it set. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-19nios2: Up the monitor size to 512kiBMarek Vasut
The monitor is growing much larger with various additions, like fitImage, command line completion, UBI etc. Make the monitor area larger so these features can be safely added. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-19nios2: Calculate the env position from monitor sizeMarek Vasut
Reorder the 10m50 and 3c120 config files such, that the environment position can be calculated from the monitor size. The environment is placed right after the monitor. This removes one more ad-hoc variable. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-21nios2: 10m50: change to ns16550 uartThomas Chou
Change to ns16550 uart for 10m50 devboard based on a new Altera release. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-12nios2: add 10m50 devboard supportThomas Chou
Add 10m50 devboard support. It is based on the Golden Hardware Reference Design (GHRD), available at, http://rocketboards.org/foswiki/view/Documentation/ AlteraMAX1010M50RevCDevelopmentKitLinuxSetup Though we supported only one nios2-generic board in the past. Now, with the removal of the nios2-generic board dir, adding new nios2 boards to u-boot is easier than before. It should be helpful to add those boards supported in Linux mainline. There are only two such nios2 boards, the 3c120 devboard and 10m50 devboard. The nios2-generic is actually 3c120, and should restore the name. The 10m50 is this one. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
