At present this option is disabled in SPL, meaning that warnings are not
displayed. It is sometimes useful to see warnings in SPL for debugging
purposes.
Add a new Kconfig option to permit this.
At present if CONFIG_SPL_GPIO_SUPPORT is enabled then the GPIO uclass
is included in SPL/TPL without any control for boards. Some boards may
want to disable this to reduce code size where GPIOs are not needed in
SPL or TPL.
Add a new Kconfig option to permit this. Default it to 'y' so that
existing boards work correctly.
Change existing uses of CONFIG_DM_GPIO to CONFIG_IS_ENABLED(DM_GPIO) to
preserve the current behaviour. Also update the 74x164 GPIO driver since
it cannot build with SPL.
This allows us to remove the hacks in config_uncmd_spl.h and
Makefile.uncmd_spl (eventually those files should be removed).
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
The Device Model sequence alias feature is required by some Uclasses.
Instead of disabling the feature for all SPL targets allow it to be
configured.
The config option is disabled by default to reduce code size for targets
that are not interested or do not require this feature.
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Stefan Roese <sr@denx.de>
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing
devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear
away the ugly logic in include/fdtdec.h:
#ifdef CONFIG_OF_CONTROL
# if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL)
# define OF_CONTROL 0
# else
# define OF_CONTROL 1
# endif
#else
#endif
Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to
CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for
SPL.
Also, we no longer have to cancel CONFIG_OF_CONTROL in
include/config_uncmd_spl.h and scripts/Makefile.spl.
As we discussed a couple of times, negative CONFIG options make our
life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ...
and here is another one.
Now, there are three boards enabling OF_CONTROL on SPL:
- socfpga_arria5_defconfig
- socfpga_cyclone5_defconfig
- socfpga_socrates_defconfig
This commit adds CONFIG_SPL_OF_CONTROL for them and deletes
CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert
the logic.
We do not want to compile the DM remove code for SPL. Currently,
we undef it in include/config_uncmd_spl.h (for C files) and in
scripts/Makefile.uncmd_spl (for Makefiles). This is really ugly.
This commit demonstrates how we can deprecate those two files.
Use $(SPL_) for the entry in the Makfile and CONFIG_IS_ENABLED()
in C files.
Allow SPL to be built with this option so that we can support device tree
control. Disable the simple bus for now in SPL. It may be needed later.
In many cases SPL only uses a single serial port and there is no need for
alias sequence support. We will just use the serial port pointed to by
stdout-path in the /chosen node.
Now CONFIG_SPL_BUILD is not defined in Kconfig, so
"!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant.
When Kconfig for U-boot was examined, one of the biggest issues was
how to support multiple images (Normal, SPL, TPL). There were
actually two options, "single .config" and "multiple .config".
After some discussions and thought experiments, I chose the latter,
i.e. to create ".config", "spl/.config", "tpl/.config" for Normal,
SPL, TPL, respectively.
It is true that the "multiple .config" strategy provided us the
maximum flexibility and helped to avoid duplicating CONFIGs among
Normal, SPL, TPL, but I have noticed some fatal problems:
[1] It is impossible to share CONFIG options across the images.
If you change the configuration of Main image, you often have to
adjust some SPL configurations correspondingly. Currently, we
cannot handle the dependencies between them. It means one of the
biggest advantages of Kconfig is lost.
[2] It is too painful to change both ".config" and "spl/.config".
Sunxi guys started to work around this problem by creating a new
configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add
%_felconfig rule to enable FEL build of sunxi platforms.) added
"make *_felconfig" to enable CONFIG_SPL_FEL on both images.
Changing the configuration of multiple images in one command is a
generic demand. The current implementation cannot propose any
good solution about this.
[3] Kconfig files are getting ugly and difficult to understand.
Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to
Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files.
[4] The build system got more complicated than it should be.
To adjust Linux-originated Kconfig to U-Boot, the helper script
"scripts/multiconfig.sh" was introduced. Writing a complicated
text processor is a shell script sometimes caused problems.
Now I believe the "single .config" will serve us better. With it,
all the problems above would go away. Instead, we will have to add
some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM,
but we will not have much. Anyway, this is what we do now in
I admit my mistake with my apology and this commit switches to the
single .config configuration.
It is not so difficult to do that:
- Remove unnecessary processings from scripts/multiconfig.sh
This file will remain for a while to support the current defconfig
format. It will be removed after more cleanups are done.
- Adjust some makefiles and Kconfigs
- Add some entries to include/config_uncmd_spl.h and the new file
scripts/Makefile.uncmd_spl. Some CONFIG options that are not
supported on SPL must be disabled because one .config is shared
between SPL and U-Boot proper going forward. I know this is not
a beautiful solution and I think we can do better, but let's see
how much we will have to describe them.
- update doc/README.kconfig
More cleaning up patches will follow this.
[trini: Fixup common/cmd_io.c]
This patch adds support for networking in SPL. Some devices are
capable of loading SPL via network so it makes sense to load the
main U-Boot binary via network too. This patch tries to use
existing network code as much as possible. Unfortunately, it depends
on environment which in turn depends on other code so SPL size
is increased significantly. No effort was done to decouple network
code and environment so far.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
